Allowable Stress
Allowable Stress
Hello everybody for instance, now i am designing a demo vessel for the first time. while designing the lug(SA 516 Gr. 70) should i take allowable stress which is 138 MPa for material and applied it as allowable bending, shear, compression, tension?
RE: Allowable Stress
This, of course, does not apply to items which are welded to the pressure boundary, as those are covered by ASME Section VIII or other applicable pressure vessel codes.
