Wood Shear Wall Max Height?
I'm having trouble understanding what the maximum allowable height is for a wood shear wall. In the NDS wood and seismic manual and there seem to be a couple of references to limiting values but I'm having trouble understanding it. Can someone help me? Thanks.
RE: Wood Shear Wall Max Height?
Mike McCann, PE, SE (WA)
So...am I then to infer that 20' tall wood shear walls allowed?
Maine EIT, Civil/Structural.
BA
Actually, stud length available is a good point. I suspect constructability and cost of using the larger size studs (2x8 and 2x10) to frame such a wall will give you the practical limit of shearwall height.
