Forming of Thermomechanical Beams - How to select Cold or Hot?
Someone to know how to find a solution to perform bending/forming on H-BEAM HEA360 with 5881mm length and bend radius of 16161mm? How can I select the forming process? Cold or Hot? Knowing that the material is S355J2+M.
Thanks for any support if available.
Luís Grácio
Mechanical Engineer (Engineering Solutions)
Portugal-Setúbal
