Symbol creation - Catia R18
I'd like to create in Catia the symbol in the attachment.
Could somebody help me in this matter with a step-by-step instruction?
(P.S. Previously created in NX as well)
MZ7DYJ
RE: Symbol creation - Catia R18
you create a view in the detail sheet, insert your BMP image it, voila.
MZ7DYJ
How could I totate a .bmp image?
MZ7DYJ
Many apps (like CATIA, PowerPoint, etc.) will also allow you to rotate the image after it is inserted into the file.
MZ7DYJ
Can you save it from NX as dxf or dwg? If yes, just open it in CATIA, then create the 2Dcomponent as suggested. You can do this with a lot of symbols, all in same drawing. After that you can save that drawing as catalog and use them from catalog. You will be able to scale, rotate, explode, replace....
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
MZ7DYJ
Actually vector data might be better is you consider scaling it...
