Journal to add appended before text to PMI dimensions
I'm by no means an expert developing journals, but the opposite, hehe... but I have been trying to made up a code that add appended before text to all the PMI dimensions in a model. My purpose is to list them as (1), (2), (3), etc... I have taken some parts of code from other threads here, and modified it a little bit. It lists the dimensions as pretended, but only the dimensions which already have a text assigned to the appended before text. If they have no text, they remain like that.
So my question is, how to list all the dimensions, regardless they whether or not have appended text?.
Here is my code so far:
CODE --> .net
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI
Imports NXOpen.Utilities
Imports NXOpen.Annotations
Module ChangeDimText
    Dim s As Session = Session.GetSession()
    Dim dp As Part = s.Parts.Display
    Dim n As Integer = 1
    Sub Main()
        Dim markId2 As Session.UndoMarkId
        markId2 = s.SetUndoMark(Session.MarkVisibility.Visible, "Edit Dimension Text")
        Dim dims() As Annotations.Dimension = dp.Dimensions.ToArray
        For Each dim1 As Dimension In dims
            Dim appendedtext1 As Annotations.AppendedText = dim1.GetAppendedText()
            Dim beforetext() As String = appendedtext1.GetBeforeText()
            For i As Integer = 0 To beforetext.Length - 1
                beforetext(i) = "(" & n & ")"
                appendedtext1.SetBeforeText(beforetext)
                dim1.SetAppendedText(appendedtext1)
                n = n + 1
            Next
        Next
        Dim nErrs1 As Integer
        nErrs1 = s.UpdateManager.DoUpdate(markId2)
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
Thanks in advance!!
RE: Journal to add appended before text to PMI dimensions
You want to loop through the existing dimensions and add/edit the appended text. The code you have loops through the dimensions then loops through the existing appended text on each dimension. I'm not sure the purpose of the inner loop, I think you can get rid of it.
www.nxjournaling.com
Ok, I got rid of the inner loop, but still I'm not sure how I could assign the text to the dimensions in the first loop... I tried with modifying the loop like this:
CODE -->
            Dim appendedlist = "(" & n & ")"
            dim1.SetAppendedText(appendedlist)
            n = n + 1
        Next
but I got the error "System.InvalidCastException: Unable to cast object of type 'System.String' to type 'NXopen.Annotations.AppendedText'. at ChangeDimText.Main() in line 29".
I'd try this (beware that it will affect all dimensions in the part, not just the PMI dims).
CODE
Dim newBeforeText(0) As String
Dim appendedText As Annotations.AppendedText
For Each tempDim As Annotations.Dimension In workPart.Dimensions
    lw.WriteLine(tempDim.GetType.ToString)
    newBeforeText(0) = "(" & n.ToString & ")"
    appendedText = tempDim.GetAppendedText
    appendedText.SetBeforeText(newBeforeText)
    tempDim.SetAppendedText(appendedText)
    n += 1
Next
theSession.UpdateManager.DoUpdate(markId1)
Awesome! that works perfect. Thank you cowski
