clean surface for sheet metaldie design
I am die designer, I receive draw surface in .iges format, lot of gaps in the surface when i open it. I need clean surface, pls suggest process to..
Dileep
Dileep
RE: clean surface for sheet metaldie design
Then we can start discussing what to do next.
Tomas
www.nxjournaling.com
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
