How to check percentage of holes in my assembly
Title said it all, how to check percentage of holes in my assembly??
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: How to check percentage of holes in my assembly
1. You can then compare volumes of the part/assembly between the configurations to compute a volume percentage.
2. You can pick the surfaces that the holes open on and compare their areas.
I am curious, though, why do you need this information?
- - -Updraft
I've forgot that I've put the question here.. Sometimes, my constructions needs to satisfy standard needs, for example I've needed this because I was constructing frame for radiator which needs at least 60% holes in it because of the inflammability needs.
Your way is good, but it's manual and I was hoping there was already a build-in option to check this. Anyway thanks for the help.
