PIGGYBACKED PIPELINE ON-BOTTOM STABILITY ANALYSIS
I am thinking of the best approach on carrying out on-bottom stability of a 4-inch gas lift line being piggybacked by a 12-inch main pipeline:
-Analyzing just the stability of the 12-inch main line (ignoring the piggybacked line) or
- calculating the equv. WT of both lines , then using it for the on-bottom stability analysis.
Please which is the best or correct approach? Is there any important consideration when analyzing stability for piggybacked pipelines?
RE: PIGGYBACKED PIPELINE ON-BOTTOM STABILITY ANALYSIS
In my "Tubular Steel Structures-theory and Design " book by Troitsky and published by er11the James F Lincoln Welding Foundation, Chapter 11 is dedicated to Underwater Pipeline. You may want to get a copy as it may pertain to your OP.
