Sec. VIII Div. 2 Centrally Located Opening in a Flat Head
First Post.
Looking at using paragraph 4.6.4 in Div. 2 for a centrally located opening in a flat head (UG-39 and App. 14 in Div.1). The equations seem manageable and I feel our application is best suited by this route. However, the opening in the head of our design does not meet the d>.5D requirement. Can I still use this paragraph despite the fact that the opening is not over half the diameter of the head? If not, can someone point me in the right direction? Everything I have seen deals with solving for large openings or exempting very small ones, I can't find where it explicitly states what to do for openings in the middle range.
jtrees02
jtrees02
RE: Sec. VIII Div. 2 Centrally Located Opening in a Flat Head
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
