Export line from SolidWorks to Parasoloid
Hello, is it possible to export from solidworks line, using parasoloid format file, just like solid body or shell body?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Export line from SolidWorks to Parasoloid
.stp (or even iges) may be a better choice of format for curve geometry such as lines.
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
.stp format seems to be better.
The point is that I need to export from SolidWorks shell model with lines at the same position as edges of shell surfaces. Then I want to import this geometry to Design Modeller (Ansys Workbench). Unfortunately there are no lines all the time...
