OMF Knee-Brace systems In seismic areas
In the commentary of 341-10. It states that knee braces can be designed as Ordinary Moment Frames. It also states that the Knee brace needs to be designed for the force that is required to develop 1.1RyMp of the beam.
This force can get very large depending on the beam size and span. I have a very larger beam in order to control vertical deflections.
For knee Braces, is there any stipulation about using the limiting earthquake force R = 1 as in Chapter E1.6.b (b) FR Moment connections
RE: OMF Knee-Brace systems In seismic areas
The greatest trick that bond stress ever pulled was convincing the world it didn't exist.
