Heat Treatment Inconel
Treating Inconel at 700°C can create any problem?
RE: Heat Treatment Inconel
UNS N06625
If there has been any welding or cold work then this temp is clearly too low.
I don't know why you would bother with this temp, you will not even get good stress relief until you heat to 850C or so.
If your service temp is below 550C then don't bother with a heat treatment unless you can go hotter.
Plymouth Tube
my concern was related to the fact that the item in 625 could be adversely affected because of this heat treatment.
It is forseen a buttering between Cr,Mo and 625 if we want to avoid treat them together, but I was in doubt about the possibility to do it.
