Error Code 529697949
Hello Guys,
I have uploaded the right image.
In my model I have a block. The side plates are fixed to the central block using a nail or peg. The side plates are encastre at the bottom and a pressure is applied on top of central block.
When I use Tie constraint between (plates and central block, Pegs and Central block and peg and plates) it works fine.
I need to have a frictionless contact between the central block and the plate. I used Surface to Surface contact(standard),Sliding formulation as (surface to surface) and Interaction property as Tangential behavior (Frictionless).
I get the following error.
ERROR: An error occurred during a write access to
C:\Users\ajay902\AppData\Local\Temp\ajay902_New_trial_1_3200\New_tria
l_1_stdSolver.local_0 file. Check the disk space on your system.
Please help me.
P.S: I would like to apologies for the wrong image I have attached in my previous post.
RE: Error Code 529697949
Your application, which you have not identified, is asserting that your computer's primary disk drive is full.
You can try defragmenting the drive, but you may have to buy a bigger one, or erase the junk from the one you have.
Mike Halloran
Pembroke Pines, FL, USA
Thank you so much for your reply.
However for the same model I have
Tried using tie constraint and it ran successfully.(after your suggestion)
Sorry for posting it here. I have simplified
My bone model as blocks to learn abacus.So I thought I can post it here. Really sorry.
