sewing extruded solid with a swept edge
I attached a prt file. This is a simple exercise that I don't understand.
I have an extruded semi-circle to which I added a nice bridge curve contour by a sweep function. At this point I unsew one face of the solid, then sew it all back up but there is always a surface in the middle of the part.
Thanks.
nx 9
RE: sewing extruded solid with a swept edge
The Unsew turns the solid into a sheet body. The surface in the middle is the surface you unsewed from the solid to make it a sheet.
What's the issue with having that sheet?
Anthony Galante
Senior Support Engineer
NX5.0.6, NX6.0.5, NX7.5.5, NX8.0.0 -> NX8.0.3
NX8.5.0 -> NX8.5.3, NX9.0.0 -> NX9.0.2, NX10 Beta
Use 'Delete Body' on it.
Anthony Galante
however I would try and avoid creating the sweep in the first place, see attached for one way of doing something like the end result.
Anthony Galante
To me this is a very backward way of working, ( on the other hand i have never understood the use of the unsew feature...)
If you wish to copy a face for other purposes, the command name is "Extract Geometry".
Why don't you include the vertical edge of the extrude such that you have a closed section to sweep, (+ Preserve Shape to keep the logical face division.)
See attached.
- Bridge Curve4 is suppressed since it's not used. delete ?
Tomas
There's still no reason why you couldn't have created your 'sweep' as a Solid to start with and then simply Unite it with the central 'core' part of the model, as I've done in the attached modified version of your model.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
yes, thanks, I was only selecting the bridge curve and not the edge of body, therefor, I was only getting sheets from the sweep. Originally I was doing this with all sheets and no bodies so I completely missed that detail. thank you.
nx 9
