how to measure static pressure of AHU
May I ask how to measure the static pressure values of an AHU? Thanks
External pressure of AHU
Total pressure of AHU or static pressure of fan unit
Static pressure of fan inlet
Static pressure of fan outlet
Static pressure of upstream of filter
Static pressure of downstream of filter
RE: how to measure static pressure of AHU
Am I correct?
Nice graphics! What was the question? Static pressure can be measured in any section of an AHU.
sorry, the picture cannot be shown in above post. my question is that, if i use an manometer to measure the static pressure at the position shown in the picture, is it right? the picture is re-posted in the below. sorry and thanks
link: https://lh5.googleusercontent.com/R2zXGkAU_7Xwk9Nv...
link: https://lh5.googleusercontent.com/rhsyn7ftRnmzR200...
link: https://lh6.googleusercontent.com/_gaNpS0JKjKGgChs...
link: https://lh4.googleusercontent.com/8Vg0o0JhVC82yrM8...
link: https://lh6.googleusercontent.com/H-gEBRG7h82csKF1...
link: https://lh3.googleusercontent.com/CBPNGzRbr3Zj29Fn...
If the pictures cannnot be shown, please click the links below the pictures. I don't know why sometime they can be shown, sometime cannot. Sorry.
All your links are error 403 for me. It's very simple. The measured static pressure at the fan outlet is the ESP (external static pressure). This is the pressure in the system downstream of the fan. The difference in pressure between the immediate inlet and outlet of the fan is the TSP (total static pressure). The TSP is all that matters when sizing fans.
Actually, the total pressure is all that is important in sizing fans.
Sorry, again the pictures cannot be shown. however, I have changed the hyperlink to anther account. I think this time the link should be valid and accessible. the pictures show how I use a manometer to measure different static values. I want to confirm whether I use the manometer correctly (both connecting to the manometer and the point I was measuring) Thanks.
link: https://drive.google.com/file/d/0B6nZP28lo52eVktBN...
link: https://drive.google.com/file/d/0B6nZP28lo52ea3k5Z...
link: https://drive.google.com/file/d/0B6nZP28lo52eWU54T...
link: https://drive.google.com/file/d/0B6nZP28lo52eSXNTS...
link: https://drive.google.com/file/d/0B6nZP28lo52eZzF5e...
link: https://drive.google.com/file/d/0B6nZP28lo52eUDNkM...
Peter ,
You have got it right except maybe for the second which should be total pressure of fan not AHU.Willard is right. SP is irrelevant as there are both static and dynamic losses in a ductwork so we should only be looking at total pressure.I remember we have had this discussion on the forum before.The attached ASHRAE article will hopefully clear things up a bit?
thanks all
Ha, Nice point Willard, sometimes that is lost... Fans/pumps produce energy. What we do w/it (flow or potential is up to us)...
SAK9/Willard. Sorry guys. TSP for fans is by difference in static only, nothing at all to do with velocity pressure.
I will prove it if you want to continue this post.
CB,I am keen to hear why only SP needs to be considered.
chasbean, sure and please tell more....thanks!
Chasbean,
Does that mean static regain is not correct?
@Chas, I totally agree with you if you mean this: Fan static pressure is the difference between Fan total and Fan velocity pressures.JMTC
What is the shape of a fan curve? Why does it end by touching the X axis? What does the Y axis mean?
I don’t mean to be elusive — I’m saying that as fan flow increases the velocity pressure increases so any fan curve would not curl down toward zero as flow reaches maximum. The performance of any fan is simply based on the static pressure at the inlet vs. the static pressure at the outlet. This is the TSP. The velocity pressure is not a component of fan curves.
Back to academia, total pressure IS static plus velocity pressure. TSP on a fan curve however does not have a velocity pressure component.
may i ask another question?
i know cfm varies as rpm and sp varies as (rpm)^2
if i measure my ahu and find the following data,
original rpm=1805
new rpm =1355
original cfm= 8.1
new cfm=6.1
original sp= 1635
but new sp=730
for the rpm and cfm, it obeys the rule; however, sp breaks the rule
"Measure wrongly" is the only reason for getting such data?
any other reason?
thanks
furthermore, if i find that all the three parameter do not obey the fan rule,
can i draw the conclusion : the existing motor and fan may be changed by someone, that's why all the three parameters i measured do not match with the nameplate stick on the AHU?
thanks
anyone can help? thanks
peterchan222
I think these rules is just theoretical rules for a theoretical specific design of the forward blade fan
so there are many factors cause difference in values between theoretical case and actual one
for example of these factors
number of blades
blades orientation (forward blade or backward blade)
curvature of blades
thickness of blades.....etc
peterchan222
But to be honest I think that all previous factors may affect on flow rate and power but The strange thing for me is to be the difference in static pressure
may be the point you measured sp in the AHU is wrong
hatem, however, i have already followed the measuring points shown on the pictures above.
yes, I have some notes on pictures
first, when you measure pressure difference you should take two points in two ducts have the same size to avoid the effect of dynamic pressure
second, all points must be not in turbulence flow area, so your point in mixing box as shown in pictures is wrong because it makes false reading
peterchan22, fan laws do say new SP is 921 and not 730 as you noted. But as previously said, fan laws are an approximation...
hatem,i can understand that the flow in the chamber is turbulent, however, where should i measure if i want to obtain the same value i need?
you can measure at point in that straight portion of AHU which is directly before filters. You may find a somewhat laminar flow in this region
important note: Don't forget that you should take points in the same duct size (the same cross section area of flow ) when measuring static pressure difference to avoid the effect of dynamic pressure
I have a 3 ton package heat pump system and have a question about External Static Pressure. The system list a max ESP 0.5 iwc. My measured ESP is .42 iwc, which includes 0.25 of the return filter. The thing I'm finding strange is the entire ESP is in the return duct, with the supply duct barely registering unless I start closing down registers. Is this an issue and why?
