Displaying expressions in notes with limits
Hi All,
I am working on NX 8.0, I need to show dimensions as limits in notes by importing as expression.
It is possible to show as nominal value only if I import any dimension to notes using expression.
Please help me if anybody have any idea.
Thanks in advance
Sandeep
RE: Displaying expressions in notes with limits
Can you clarify what you mean by nominal value?
If without decimals then you need to change amount of decimals when you select the expression (Format field as in attached picture Decimals)
Or you can change it in the Annotation editer afterwards by changing the 2 ( as indicated in red box picture Decimals-02 ) to 0 (amount of shown decimals)
Ronald van den Broek
Mechanical Engineer
Cad Environment Coordinator
Wärtsilä, Propulsion Services
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP EliteBook 8570W Intel(R) Core(TM) I7-3740QM CPU @ 2.70GHz, 16Gb Win7 64B
Somehow the second picture wasn't accepted.
Attached it again in here.
Mechanical Engineer
NX8.5.3 / TC9.1.2
