Export CGM Filename
Export CGM Filename
Morning,
Does anyone know if it is possible to change the default style of filename for an exported CGM (exported to windows) from NX8.5?
For example, if we export 123/A1234 revision A the file comes out as 123SA1234_DWG_A, but when we export to Teamcenter the format is taken from sheet name in part navigator i.e. 123-A1234-A-SHEET1
Apart from having to rename for every export, this also means we need to export multi-sheet drawings one-by-one, as otherwise all sheets have the same filename.
So, is it possible to export CGMs to windows using the sheetnames from Part Navigator, in the same way as the "export drawings to Teamcenter" command works?
Thanks, Carl
Thanks, Carl
www.jcb.com
NX 8.5 with TC 8.3
RE: Export CGM Filename
There is a program on GTAC which you could use - https://solutions.industrysoftware.automation.siem...
or search for 'make_cgm_and_tif_of_all_drawing_sheets'. Just remove the TIFF bit.
Mike Hyde
www.astonmartin.com
NX8.5 with TC9.1
Thanks for this, looks like it might be possible then!
I ran the program but it returned an error of "specified filename is invalid" at line 97.
Line 97 is the final line in this section:
sheetName = "Printing Sheet: " + mySheet.Name
cgmFileName = tmp_dir + "\" + partName + "_" + mySheet.Name + ".cgm"
ufs.Ui.SetPrompt("Waiting for CGM file: " & cgmFileName)
plot.SaveCgm(mySheet.Tag, jobOptions, JobName, bannerOptions, cgmFileName)
So I'm guessing this is something to do with either the filename being created, or possibly the directory I'm saving to.
The error refers to C:\Users\me\AppData\Local\Temp\NXJournals15008\journal.vb:line97
I've had a look, and there is no NXJournals... folder inside Temp
Unfortunately I have zero programming knowledge, but also our normal CAD boxes wouldn't have access to the C drive.
So do you or anyone know how I can change this journal to specify my own directory, and ensure name is correct?
www.jcb.com
NX 8.5 with TC 8.3
CODE
cgmFileName = tmp_dir + "\" + partName + "_" + mySheet.Name + ".cgm" msgbox("cgmFileName: " & cgmFileName) ufs.Ui.SetPrompt("Waiting for CGM file: " & cgmFileName) plot.SaveCgm(mySheet.Tag, jobOptions, JobName, bannerOptions, cgmFileName)Make note of the value, it probably has characters not allowed in a file name or points to a folder location that does not exist.
www.nxjournaling.com
Thank you very much, you were right the filename included the part name, which includes slashes.
So I've cut that bit out as I don't want it anyway, leaving just:
cgmFileName = tmp_dir + "\" + mySheet.Name + ".cgm"
I had a similar error at line 126 relating to TIFFs, but I don't want TIFFs.
So, I guessed which lines to delete, ran the journal again and it worked! I am completely stunned!
Attached are the versions with and without TIFFs.
Would you mind having a look just to check I haven't deleted anything critical?
And final (stupid) question, how do I change the location where it's putting the CGMs to e.g. H:\My Documents\Carls Documents ?
www.jcb.com
NX 8.5 with TC 8.3
I've added a variable for the output directory (outputDir), change this value as desired.
CODE
' ------------------------------------------------------------------------- ' This example loops through all the sheets in the part. ' For each sheet, we open the sheet, update all views in it, and then ' create a CGM of that sheet. ' ------------------------------------------------------------------------- Option Strict Off Imports System Imports NXOpen Imports NXOpen.Utilities Imports NXOpen.UF Imports NXOpen.Drawings Imports System.Text Module make_cgm_of_all_drawing_sheets Dim s As Session = Session.GetSession() Dim ufs As UFSession = UFSession.GetUFSession() Dim plot As UFPlot = ufs.Plot Dim lw As ListingWindow = s.ListingWindow Sub Echo(ByVal output As String) s.ListingWindow.Open() s.ListingWindow.WriteLine(output) s.LogFile.WriteLine(output) End Sub Sub Main() ' ' ----------------------------------------------- make sure we have a part Dim this_part As NXOpen.Tag Try this_part = s.Parts.Work.Tag Catch ex As Exception If this_part = NXOpen.Tag.Null Then MsgBox("You need an open part to run this program.", MsgBoxStyle.OkOnly) Exit Sub ' no part, so exit program gracefully End If End Try ' ------------------------------------------------------------------------- Dim workPart As Part = s.Parts.Work Dim workView As View = s.Parts.Work.Views.WorkView Dim drawingSheets As DrawingSheet() drawingSheets = workPart.DrawingSheets.ToArray Dim mySheet As DrawingSheet Dim JobName As String = Nothing Dim tmp_dir As String = Nothing Dim outputDir As String = "H:\My Documents\Carls Documents" If Not IO.Directory.Exists(outputDir) Then MsgBox("Specified output directory does not exist: " & outputDir, MsgBoxStyle.OkOnly, "Error") Return End If Dim partName As String = workPart.Leaf.ToString Dim sheetName As String Dim cgmFileName As String Dim jobOptions As UFPlot.JobOptions Dim bannerOptions As UFPlot.BannerOptions = Nothing plot.AskDefaultJobOptions(jobOptions) plot.AskDefaultBannerOptions(bannerOptions) ufs.UF.TranslateVariable("UGII_TMP_DIR", tmp_dir) For Each mySheet In drawingSheets '----------- Iterate through the sheets mySheet.Open() ' ------------------------------------------------------------ Update Views s.Parts.Work.DraftingViews.UpdateViews( _ DraftingViewCollection.ViewUpdateOption.All, mySheet) ' ---------------------------------------------------------------- Plotting sheetName = "Printing Sheet: " + mySheet.Name 'cgmFileName = tmp_dir + "\" + mySheet.Name + ".cgm" cgmFileName = IO.Path.Combine(outputDir, mySheet.Name & ".cgm") ' msgbox("cgmFileName: " & cgmFileName) ufs.Ui.SetPrompt("Waiting for CGM file: " & cgmFileName) plot.SaveCgm(mySheet.Tag, jobOptions, JobName, bannerOptions, cgmFileName) Next '------------------------------------------ End of the FOR-NEXT loop ufs.Ui.SetPrompt("Finished") End Sub Public Function GetUnloadOption(ByVal dummy As String) As Integer GetUnloadOption = UFConstants.UF_UNLOAD_IMMEDIATELY End Function End Modulewww.nxjournaling.com
Thank you, I see you've also deleted my leftover references to TIFF!
I'm now getting a filename error again, which still makes reference to the TEMP directory, and line 102 now which is:
So I checked the filename using your message box and it comes up:
cgmFileName: H:\My Documents\Carls Documents\123-A1234-1-SHEET1.cgm which looks correct
So I'm confused why this new error in the temp directory... would you know why?
Apologies for asking again.
www.jcb.com
NX 8.5 with TC 8.3
I will try a few more locations and files and see how it goes.
Thank you cowski and mike for your help, much appreciated!
www.jcb.com
NX 8.5 with TC 8.3
Thanks again
www.jcb.com
NX 8.5 with TC 8.3
CODE
cgmFileName = IO.Path.Combine(outputDir, mySheet.Name & ".cgm") If IO.File.Exists(cgmFileName) Then Try IO.File.Delete(cgmFileName) Catch ex As Exception 'could not delete existing file 'take appropriate action 'such as warning user of error and exiting journal MsgBox("Cannot over write existing file: " & cgmFileName & ControlChars.NewLine & _ "Please close the file if it is open and try again", MsgBoxStyle.OkOnly, "Error") Return End Try End If ' msgbox("cgmFileName: " & cgmFileName) ufs.Ui.SetPrompt("Waiting for CGM file: " & cgmFileName) plot.SaveCgm(mySheet.Tag, jobOptions, JobName, bannerOptions, cgmFileName)www.nxjournaling.com
I've done some more testing this morning.
I think the error is due to choice of output directory, and related to some problems my laptop is having with synchronising. It's due a rebuild to fix the problems but I'm too busy at the mo!
I've changed the folder a few times, and with some it always works, with others it always fails reporting specified filename is invalid.
In the directories that work, it has no problem overwriting existing files (I've made minor changes to check).
So I'm going to send it to a few people to see if it works.
Attached is the final version if anyone's interested, thank you very much for your help.
www.jcb.com
NX 8.5 with TC 8.3
If other people are going to be using this program you may wish to add in some code to allow them to select the output folder. Insert this where after your line ' ***---------CHANGE YOUR OUTPUT DIRECTORY----------***
CODE
Dim outputDir As String outputDir = GetSetting("NX journal", "Export CGM", "ExportPath", "H:\My Documents\Carls Documents") Dim FolderBrowserDialog1 As New FolderBrowserDialog With FolderBrowserDialog1 ' Desktop is the root folder in the dialog. .RootFolder = Environment.SpecialFolder.Desktop If IO.Directory.Exists(outputDir) Then .SelectedPath = outputDir Else .SelectedPath = "H:\My Documents\Carls Documents" End If .Description = "Select the directory to export STEP file" If .ShowDialog = DialogResult.OK Then outputDir = .SelectedPath ' save the output folder path in the registry for use on next run SaveSetting("NX journal", "Export CGM", "ExportPath", .SelectedPath) Else 'user pressed 'cancel', exit the subroutine outputDir = 0 Exit Sub End If End WithYou will also need to add
CODE
Each users' output folder selection will be saved to their registry to be re-used next time they run the program.
Mike Hyde
www.astonmartin.com
NX8.5 with TC9.1
Thank you for that, makes sense what it's doing.
I'm going to be pretty tied up for the rest of this week, so I'll have a go at it early next week and let you know.
In the meantime two quick questions:
1. It refers twice to Carls Documents - presumably this won't be a problem for the folder browser?
Particularly in the line Else .SelectedPath ?
Or should they use their own name (or a default that won't fail) in these two bits of code?
2. Where do I add Imports System.Windows.Forms ?
Apologies again for the questions, it's probably obvious but I'm no programmer!
On a bright note, the version created earlier has now been tested with good feedback.
www.jcb.com
NX 8.5 with TC 8.3
It probably would be better to assign a string with the folder name and replace both instance of the folder name with the string variable. The first instance of Carls Documents is defining a default folder if the registry doesn't return a value. The second instance is in case the selected folder does not exist - quite unlikely if the user has selected it, so it could possibly be deleted.
This is just some code I grabbed from one of our programs so I haven't looked at it for a while. I tend to just grab blocks of code to reuse in other programs. You could set the default folder for each user with Environ("username") in the folder name, depending on your folder names.
The Imports statement goes at the beginning of the journal where you will find other Imports statements.
Despite your denials, you are now a programmer. Maybe only a beginner, but as you are getting good feedback it won't be long before they want more!
Mike Hyde
www.astonmartin.com
NX8.5 with TC9.1
To prove my point: assign a string with a folder name? Environ("username")? - now I am lost!
That said, I'm happy to have a crack at it next week, what's the worst that could happen.
Thanks again for your time.
www.jcb.com
NX 8.5 with TC 8.3
CODE
If IO.Directory.Exists(outputDir) Then .SelectedPath = outputDir Else .SelectedPath = "H:\My Documents\Carls Documents" End Ifto:
CODE
If IO.Directory.Exists(outputDir) Then .SelectedPath = outputDir Else .SelectedPath = My.Computer.FileSystem.SpecialDirectories.MyDocuments End IfIf the saved directory path no longer exists (it was moved or deleted since the last run), this will point to the current user's "My Documents" directory; you will not have to determine the current user, the code will do that for you.
So I'm having a go at making these changes to bring up the output directory selection.
I've added the code provided by MikeHyde, and changed the line Else .Selected path to the "MyDocuments" line as per cowski's post.
Three questions:
1. Our MyDocuments directories are on the H drive, presumably this won't be a problem?
2. This still leaves the first reference to Carls Documents in the line outputDir. I was completely lost at this:
"You could set the default folder for each user with Environ("username") in the folder name, depending on your folder names."
and I am still lost?
3. Running this journal, I have an unexpected error which is:
Line 57: 'View' is ambiguous, imported from the namespaces or types 'System.Windows.Forms, NXOpen'.
Line 57 was in the earlier version of the journal and hasn't changed, but the earlier line
has been added.
Is there something else I need to do here?
Thanks in advance, Carl
www.jcb.com
NX 8.5 with TC 8.3
will point to your "My Documents" folder as defined in Windows; this is the location shown when you click on the Win start button, click on your username, and double click the My Documents folder. If this takes you to the H drive, then all is well. If this takes you to a different location, you'll have to add a bit more code as suggested by Mike.
CODE
Dim workView As NXOpen.View = s.Parts.Work.Views.WorkViewwww.nxjournaling.com
Thank you very much for the info, that's got rid of the error I saw and it's working on my computer!
And yes I think it should go straight to the H drive for people in the line:
Else
.SelectedPath = "My.Computer.FileSystem.SpecialDirectories.MyDocuments"
I will get some people to test it first, but that makes sense.
Unfortunately I am still confused by number 2, although I don't think I've explained properly.
Earlier in the journal, a line says:
And I don't know what I'm supposed to write here so that anyone can use it?
Thank you again for your help.
www.jcb.com
NX 8.5 with TC 8.3
outputDir = GetSetting("NX journal", "Export CGM", "ExportPath", "H:\My Documents\") ?
www.jcb.com
NX 8.5 with TC 8.3
http://msdn.microsoft.com/en-us/library/kb0c3wb9%2...
What you currently have will also work for any user, but may be a bit confusing if/when you revisit the code at a later date. When I run the code and there is no value in the "ExportPath" key, "H:\My Documents\Carls Documents" is returned as the outputDir. The If block then checks to see if this path exists; of course it doesn't exist on my computer so it then sets the outputDir to My.Computer.Filesystem... which does exist on my computer. So, even though it works, you could simplify the code by using one of the strategies above.
Thank you for your description, think I understand (it's taken me a while)!
So the folder at the end of outputDir line will be the pre-selected folder in the browser, unless there is a stored folder in the registry key "ExportPath", which comes earlier in that line.
And if the specified folder doesn't exist, the if function would sort out that problem anyway.
For simplicity, I'll leave the line as:
outputDir = GetSetting("NX journal", "Export CGM", "ExportPath", "H:\My Documents")
So final version of the journal with browser selector is attached.
And yes you're right, for CAD models the aim should always be clarity.
Thank you and Mike for your help, Carl
www.jcb.com
NX 8.5 with TC 8.3
So that's you first program done. Have a look around on Eng-Tips but also on GTAC and Cowski's site (NXJournaling) for more ideas for your next one, now you are a programmer!
Cowski
Sorry to leave you picking up the pieces after me making some suggestions. I learnt some new tricks as well though from it. I'm in the middle of a Check-Mate course so haven't been able to contribute this week. KF is not as friendly to use as VB.
Mike Hyde
www.astonmartin.com
NX8.5 with TC9.1
Carl did the hard work, I just gave some advice along the way.
Carl,
Congrats on your finished program, I have a feeling it won't be your last!
I did wonder about producing EMF files from the plot menu in the same way, for design presentations etc. (as CGMs vs MS Office has reared it's head again), but I'm already booked up for most of October so that will have to wait.
Which suits me fine, my head has turned to mush.
www.jcb.com
NX 8.5 with TC 8.3
