Determining lLfting Capacity of motor/gearbox
I don't have a background in mechanical engineering however I need to determine the lifting capacity of an existing motor in a roof space so I can design/upgrade the supporting structure and pulley system accordingly.
I have contacted the manufacturer, Varvel (Italian based company), and they sent through the following details:
"Description of the entire unit is STA63/60 ratio 630/1 (6.3x100) output torque 122 Nm
and efficiency 0.35 - max input power for SF1.0 is 0.08 kW."
The radius of the pulley/drum is 0.15 m.
It is currently lifting approximately 150 kg (1.5 kN).
I assumed the lifting capacity to be output torque/radius of pulley = 0.8 kN but that is clearly not correct.
Any help would be greatly appreciated!
Thanks.
Thanks.
RE: Determining lLfting Capacity of motor/gearbox
But does the gearbox alter the load capacity?
Also would a tong test help determine the maximum load?
I don't know what a "tong" test is.
I'm too lazy to check the numbers right now but you should do this check:
Output power (of the gearbox) = input power (of the motor) x efficiency.
