PMI equivilant of the feature parameter command
thread561-341497: PMI using feature parameter
I asked this question a while back.
I am still looking for a PMI equivalent of the feature parameter command.
Any word?
Any word?
RE: PMI equivilant of the feature parameter command
There is no exact equivalent. However, you can already set any Sketch dimension to be a PMI object as well as, starting with NX 9.0, you can create Hole Callouts in both Drafting and PMI. So between the two of those capabilities, it pretty well allows you to create PMI objects similar to what you could do with the 'Feature Parameter' command in Drafting.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
At my company we are detailing our parts exclusively in PMI. That means we have no drafting sheets or any thing at all besides the PMI.
To be clear I am looking for a way to put a call out for a threaded counter sunk hole. All of the data is entered in the hole command at the creation of the hole and can be changed a any time by modifying the hole feature.
To me this would mean that I should be able to put a hole call out that gives me all of the information about that particular hole and even if I changed it from a counter sunk hole to a counter board one it should update the call out.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I have tested it out and it seems to work for the counterbores and countersinks. Looks good.
Threaded holes however are not working out so nice. Normally we call out UNC or UNF but this dose not seem to be a property I can enable in the list of parameters. It puts every thing else in there. Just not the thread series or standard.
