Slider crank mechanism
I am trying to make a slider crank mechanism only in vain.I give you below the list of joints i made.
Revolute joint : between the support and the crank.
Revolute joint : Between the crank and the connecting rod
Revolute joint : Between the connecting rod and the slider
Prismatic joint : Between the slider and its support.
Rigid joint : Between the connecting rod and crank.
Awaiting your replies.Please let me know how to simulate this mechanism in CATIA Kinematics.
Sudhakar.N
Sudhakar.N
RE: Slider crank mechanism
Without waiting for the part, I already see a problem here, unless I don't understand crank/shaft mechanism
