Macro to Create Plan View Camera (under View > Named Views)
I am in need of a VBA macro that creates a camera for a standard, 3rd angle projection, plan view (Looking in -Z, +Y is up, +X to the right), then I need to "activate" that view (so the part orients to the camera created)...but I a not sure where to start.
-I have point coordinates where I could set my ViewPoint3D (if that is possible)
-The -Z is the SightDirection
-The +Y is the UpDirection
Any help would be greatly appreciated.
RE: Macro to Create Plan View Camera (under View > Named Views)
Fernando,
This was exactly what I needed! I modified the "custom" view to the vectors I needed, and had to comment out the type on the Viewer3D (function marked as restricted) and it worked perfectly! Thanks!
Where are all these example scripts stored? I had to search for the file name you posted.
Do you have anything creating TPSview planes for 3-D annotations? I can create the views but I am having trouble orienting the views to make the text go in the direction I want.
that is tricky as API not documented if my memory is good.
Do you have code we can look at?
Eric N.
Sure, so I thought the TPSViews were only related to how the geometry was oriented. So if I wanted to view my text in the plan view I needed to orient the geometry in the plan view before creating the TPSView.
So I would use the code above to orient to the plan view, create my annotation set, then I used the following code to create the view:
oSelection.Clear
oSelection.Add oPlane
oRefPlane = oSelection.Item(1).Reference
oView = oTPSFactory.CreateView(oRefPlane, 1)
oView.Name = "View Name"
oSelection.Clear
The view is created but the text was bout oriented properly. Horizontal was in the Y (up). There is a field in the TPSview definition (I'm using V5 R22) that allows you to align the horizontal of the view to a line...not sure how to access that in VBA though. The chm does not give good information on TPSViews.
i remember I had to first create a AXIS // to screen with vector matching screen vertical using ViewPoint3D.PutSightDirection and ViewPoint3D.PutUpDirection.
I used this axis in the creation of the view.
That was a while ago... have to go back to code to find out, but wont be able to share code (sorry)
Eric N.
So I figured out if you create a plane from 2 lines that are perpendicular (pick horizontal then vertical), then create a TPSView on that plane, the view horizontal and vertical will match the plane's horizontal and vertical.
that's why we created an Axis that would match the screen orientation...
Eric N.
