Blanked objects error after running checkmate
RE: Blanked objects error after running checkmate
Are you saying that you did not want to check for blanked objects or is it that now that you've found that there are blanked objects, that you want them 'unblanked'?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
yes i want to unblank those blanked objects and rerun checkmate to clear those error.
For your reference i have uploaded pic, in that pic i have highlighted the error. i am unable to find those blanked objects to unblank or to delete.
Please get me solution.
Have you tried "Invert shown and hidden" or "Show all"? Are you wanting to do this within checkmate?
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
What 'test' did you invoke which resulted in this 'error' indicating that there were 'blanked' objects?
Also, were you aware that once you had that listing in the HD3D window that you can select an object using your cursor and then press MB3 to access operations that can be performed on that object, such as changing its status from Hidden to Shown?
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
@ewh- i have tried with Invert shown and hidden and show all i am unable to view that blanked objects
in checkmate on of the criteria is to check blanked objects are there are nor. when we run with this criteria i am getting error like this.
yes JohnRBaker using that HD3D window if i go for show objects also i am unable to see that objects.
Turn on all layers and show all?
www.nxjournaling.com
@cowski i did that too.
