Reducing the length of a DWT Pump
We have a deep well Turbine (DWT) type pump installed at our pump house. The minimum water level remains 8 feet above minimum submergence of pump. Due to high silt moving into the pump house we are thinking about reducing the length of pump in the pump house. We are planning to reduce the length by 4 feets (by reducing one of the middle shaft length and reducing one column length). By doing so we will still have a 4 feet water above the minimum submergence level of this pump. I need advice before doing this. What things we should keep in our mind. Does it is going to have any negative effect on its discharge head.
Help needed. Moiz Khan
RE: Reducing the length of a DWT Pump
Issues to think about are to check the NPSHr to see if you're still within it by a reasonable margin (3-4 ft min above NPSHr is recommended) and 4 feet coverage could start to induce a vortex if the inlet is vertically upwards and there are no anti vortex plates. Hence over time if a vortex does appear you could suck air in. 4 feet is probably just on the limit, but it depends on your flowrate, inlet size and shape and inlet velocity into the pump.
The only other thing to consider, hydraulic institute has guidelines for distance from sump floor to suction bell (1/2 to 1/2 bell diameter.) There can be flow disturbances with open spacer under the suction of the pump. Probably only a concern if flow is more than 10,000 gpm (arbitrary guess.)
OP also has indicted that submergence is 4ft above minimum submergence.
However if the silt load is high what advantage do you see in raising the pump? if the silt has time to settle before being pumped then you are only delaying the time before it reaches a level to become a problem once again.
Probably better installing a small hard impeller pump in the sump to handle the silt as it builds up.
When shortening a vertical pump from its original length MAKE SURE you check with manufacturer to see if there could be a conflict with your new natural frequency moving into the neighborhood of running frequency. Its a small chance of actually happening, but if it does you will go through a lot of failures and fingerpointing before you figure out what it is.
Just to be clear (I think everyone is) but minimum submergence value and NPSHR value are not the same and should not be confused as such. Min submergence is to prevent vortexing, NPSH is to prevent cavitation. You can easily have plenty of Min submergence margin and still cavitate.
1. As shown in the sketch NPSHr is 17.5 feet.
2. As you see in this case currently NPSH available is 32 + 8 = 40 feet
3. With respect to submergence the sketch shows the clear picture.
4. As shown the discharge flow is 7600 IGPM at 4.55 psig discharge pressure
5. Water temperature is 26 to 28 C
6. The pump is a closed shaft pump with rubber lined bearing with demineralized water supply
7. The silt settling rate is 4 inch per year at average.
Hence, as advice I have to do vibration analysis and check that the running frequency of modified pump is not closed to the natural frequency of modified pump.
Does the discharge flow and pressure remains the same?
One area to be considered about is creating a vortex and air entrainment with the lower submergence.
You should have a quality pump repair shop make this adjustment for you.
The big advantage of this is that you avoid touching the pump and its shaft / column. If your lift was actually a single stage then it would be easier, but I would be wary of making these changes and expecting any vendor to guarantee it unless they do it themselves.
doing it this way should also be a bit faster
changing the pump length, although not my solution to the problem, is easy, and straightforward.
There might not be physical room to lift it 4 feet in the air, but it all depends who is changing the pump length - the pump vendor or some other contractor...
In the OPs case the tidal change in water level will affect the output head / pressure but that will be the same regardless if the pump was at the bottom or the top of the sump providing it is under water.
The head created by the pump between water level and existing discharge pipe, will not change no matter where you put the pump, within reason.
When calculating static head on a submersible pump the measurement is from the standing water level in the sump to the reference point under consideration, irrespective of the pumps location below water level.
1gibson: Quote. Raising the pump 4ft would actually decrease the head 4 ft *at the discharge flange* because now that point of reference is 4 ft higher elevation. Unquote.
Did you intend to say increase the head rather than lower the head?
N.B. I have requested my post of 22 Sep 14 7:45 to be removed as I included contradictory info (late at night in my part of the world)
just to summarise here I believe we all now are of the same view, i.e. raising your pump 4 feet, but still under water, will not affect the discharge head seen by your surface pipework from current conditions, noting that this head will vary by tide level as I'm sure you are aware.
If you take up my suggestion of simply raising the whole pump as it is 4 feet by building a structure between pump mounting and the surface, then the head at the discharge flange will be 4 feet less, but if the pipework is then elbowed back down to the current pipe, this difference will disappear.
So, now i would lift the pump inlet by 4 feet. By removing the middle shaft and middle column in such a way that the pump length would reduce by 4 feet. The discharge remains at its current point and i am not going to disturb the outlet piping network. I think we have adequate skill to reduce this assembly perfectly. It is a single impeller pump. i would take care of the rubber lined bearing and its placement. But i would have to check for vibration analysis and natural frequency discrepancy. By the way this is an old pump manufactured in 1963. The manufacturer is out of market.
Moiz Khan
Messing around with anything 50 years old(!) would seem to be not a good thing. As soon as you take this thing apart to modify my guess is that you'll end up replacing most of the pump. what material is this made of that has lasted 50 years in sweater??
