cryogenic fluid
cryogenic fluid
cryogenic fluid
hi.....
I want to know that, is there any special consideration in ASME vessel design for cryogenic fluid?
Thanx in advance.
RE: cryogenic fluid
What pressure, what temperature, what cooldown and thermal shock rates, what service, what cryo fluid? How much volume? How much expansion room at the top for vapor? How much leak off/vapor recovery/pressure relief and how will you protect the workers/nearby non-workers/nearby facilities and operations from an accident? Loading/unloading/venting/flushing methods?
Your question is much like asking: I am going to build a car. What special considerations do I need to keep in mind.
