DIv 1 : Hydro pressure is Exceed 3000 psi, Can U stamp Possible ?
RE: DIv 1 : Hydro pressure is Exceed 3000 psi, Can U stamp Possible ?
If you read U-1(d), you'll notice the 20 MPa (3000 psi) is not a 'hard' limit, but a limit where the Code addresses that the common DBF rules are usually not well defined for these conditions, and extra provisions are required.
