MWAP in FRP storage Tank
Hello everyone,
I was asked to calculate the MWAP for an FRP storage tank.
Is calculation the same as per API 650?
Rich
Rich
RE: MWAP in FRP storage Tank
Mike
All I have a GA drawing. it says FRP Tank in accordance with spec ASTM 3299.
API 650 is not mentioned anywhere in the drawing.
Rich
Is API 650 is not limited to steel fabricated tanks?
Maybe you have to refer to ASME Section X?
Kurt
ASME X is what FRP pressure vessels get built to. And they are impossible to reverse-engineer. The tensile of the yarn, the winding angles [must be more than one], fill factor, use of 'chop', ester mix and cure conditions all have 'order of magnitude' impacts on the strength of a FPR tank/vessel.
If I had to certify an unknown one, I would fill it 98% (+) full of water and GENTLY pressure it up with air/N2/Ar to 0.5 to 1.0 psi, then certify it to one-third to half of that test pressure. And that constitutes $iss-Poor Engineering. If you want a good one, buy a good one. Doggy doo-doo is tough to certify.
These tanks should be operated at atmospheric pressure and provide for extra venting during liquid delivery
Several FRP tanks have failed because the owner/specify failed to include an emergency relief vent on the tank.
http://www.eng-tips.com/viewthread.cfm?qid=363083
MJCronin
Sr. Process Engineer
