xml-errors on DraftSight startup (DraftSight x64 Version 4, Windows 7)
thread1480-336108: XML Crash and Lost Toolbars
Hi guys,
I have read the former thread according this problem and I had the same issue, though it didnt work out for me. It seemed to have corrupted the "application.xml" file in my Draftsight folder
So I have tried this:
C:\Users\<Username>\AppData\Roaming\DraftSight\1.2.285\UI\english --> copy the application.xml and paste it into the language folder that you are using
in my case it was the german version:
C:\Users\<Username>\AppData\Roaming\DraftSight\1.2.285\UI\german
I think it works viceversa. I did not try that though, because it is running smoothly since.
greetz
Hi guys,
greetz
