Which CONSTRAINT I have to use?
I have a doubt. In my model I have a block. The side plates are fixed to the central block using a nail or peg. My question is which constraint I have to use for the plate and the central block?
P.S I need to have a frictionless contact between the central block and the plate.
Thank you so much!
Aravind
RE: Which CONSTRAINT I have to use?
Thank you so much!
Aravind
PLEASE IGNORE I HAVE UPLOADED WRONG IMAGE
