Selection of Section I paragraphs from different parts
When using ASME B&PV Section I, some topics are not in Part General, but in one of the specific parts like PFT (firetube boilers) or PWT (watertube boilers). For example:
(*) external pressure is covered by Part PFT (PFT-50 covers some rules for cylinders (tubes) under external pressure). When I'm designing a watertube boiler, how are the external pressure calculations covered? It seems strange to me that I need to decide myself to apply a paragraph that is not in part PG or PWT while designing a watertube boiler.
(*) attachment of tubesheets is covered by PFT-11. When I have a tubesheet in a watertube boiler, how should I analyze the tubesheet attachment. There is no reference in Part PG or PWT to PFT-11.
Am I missing something. I'm experienced in the analysis of pressure vessels conform Section VIII. With this experience, it is hard to understand what should be in your Section I analysis as explained by the above examples.
Thanks for comments and response.
RE: Selection of Section I paragraphs from different parts
TS's: the TS on WT and TS on FT are completely different; and yes there are rules for TS's of WT in the WT and PG sections. good luck. GenBlr
I'm now in the phase of studying the design calculations for boilers in general, without having a specific design.
Coming from generic Pressure Vessel design, it takes some time to get acquainted with boiler specifics. However, thinking it over somewhat more, I now see that it is not possible to have external pressure on components of a WT.
Nasir
Welding Engineer
DESCON ENGINEERING LIMITED
PAKISTAN
