Pump Curve - Centrifugal Vs Air Operated Diaphragm Pump
Hi all,
Need your help as bit confused..
Please let us know if my below understanding is correct.
Normally, the pump curve is plotted for HEAD vs FLOWRATE
1) For centrifugal pump, this HEAD is nothing but the TOTAL HEAD i.e. the difference in total discharge head required – NPSHa
2) For air operated diaphragm pump, this HEAD is nothing but the total discharged head required
I believe this is because, air operated diaphragm pump capacity depends on the air supply pressure and not the NPSHa.
Any pointers please.
Thanks in advance
KS
Thanks in advance
KS
RE: Pump Curve - Centrifugal Vs Air Operated Diaphragm Pump
Good luck!
SShep
An AODP provides the maximum head possible based on air pressure available. It is less sensitive to inlet pressure but then simply needs less air / less work to deliver a fixed outlet pressure if the inlet pressure rises.
I haven't had much experience of AODs, but see this which might be useful.. http://www.globalpumps.com.au/resources-support/us...
KS
