HS 98 regulation program
I have a Gemini FO 3015 Laser
When I go to run the HS98 Regulation program for the heigth control the head will come down to about 3 inches from the plate and then stop. It never makes it down to the plate to sense it. It doesn't throw any alarm it just stops and sits there. In the program it shows that it has stopped on a M727 in the program. Any ideas on this would be greatly appreciated.
RE: HS 98 regulation program
From the tip of the nozzle to the inside of the SMB connector should read less than one Ohm (or there about).
