Seamless pattern around extruded profile (made of splines)
Hi! I would like to have a cut extrude around a profile with a seamless pattern. What is the best way to do this? I tried wrap, but got all kinds of problems (maybe wrong settings?), sheet metal is not possible since it is made of splines (correct?), and a curve driven pattern gave problems at the end points. Any ideas? Thanks!
http://www.mediafire.com/download/ajj045yye8j3ndy/...
RE: Seamless pattern around extruded profile (made of splines)
You would be better off making that into a decal and placing it on the outside of the part instead.
Scott Baugh, CSWP
FAQ731-376: Eng-Tips.com Forum Policieswww.superATV.com
www.scottjbaugh.com
