Prony Series Calculation
HI everyone,
I'm working in ANSYS with a thermoplastic polymer and I need to model the Prony series in order to insert the viscoelastic properties. But I've found a little bit tricky found the coefficients. If someone has a script with an explicit method about how to calculate it or if you have any advice related to the viscoelastic simulation I will apreciated.
Thanks.
