Pump Working Pressure and Flange Rating
Dear Friends,
I need to know the relationship between pump working pressure & flange class rating...
For example (Pump working pressure 325 psi and flange drilled to PN16 ....
Note: if this subject has been discussed before, please send me the link.
Waseem
Waseem
RE: Pump Working Pressure and Flange Rating
The relationship is quite simple - maximum pump discharge pressure (considering worst case inlet pressures) MUST be lower than the discharge flange rating at the operating temperature. This applies to any piping system, not just pumps.
Note that the design maximum may be with the biggest impellor and not your particular case, but you're only giving us snippets of information so it's difficult to see why the vendor has done this. Maybe the density of the fluid you're pumping is quite low? Who knows?, only you and you're not giving us much to go on here.....
