Plate Gasketed heat Exchangers
Which processes are involved in the manufacturing of Plates of Plate heat exchangers???
Is it sheet metal pressing and cutting or there is some other process involved??
RE: Plate Gasketed heat Exchangers
Plates could be made by photoetching or laser cutting or plasma cutting or shearing or punching or ...
Mike Halloran
Pembroke Pines, FL, USA
The problem with sheet metal pressing is that they use a special white fluid so that the metal sheet may not burst open when pressed in a die to create different patterns on the heat exchanger plate. I am not sure that the fluid is hygenic or not, because the heat exchanger is to be used in a dairy industry. Thanks for your help anyway :)
@tbuelna the heat exchanger has to be used for dairy industry i.e. for the treatment of milk i just want to know the conventional Plate heat exchanger manufacturing techniques like shearing and stamping enough and are hygenic or not. Thanks for your help anyway :)
@both of you can i get the name of some book regarding heat exchanger manufacturing????
Use of any of several key words would have changed the answer you got.
SANITARY gets you something that arrives clean and is easy to clean.
DAIRY gets you something specifically adapted to the milk industry.
A search on sanitary heat exchangers should be productive.
A search on dairy heat exchangers will get you the exact products you seek to design.
The SME Die Design Handbook covers a lot of topics related to hx manufacture, but is not solely about heat exchangers.
Mike Halloran
If the heat exchanger core is constructed using a process like furnace brazing, then the stamped plates would need to be thoroughly cleaned of any surface contaminants prior to brazing. So there should not be any trace of lubricants used to shear/form the plates after brazing.
Regarding your specific question in the last post about whether the typical processes used to shear/form sheet metal are "hygienic or not", the answer is definitely no. The raw sheet metal is not delivered or maintained under hygienic conditions. The machinery and tooling used to shear/form the sheet metal is not operated under hygienic conditions. And the shearing/forming process involves non-hygienic materials coming into contact with the sheet metal.
I'd look particularly at the gasketing if you're worried about hygiene, because if they are designed wrong there is no doubt there will be plenty of places where material could hang up and resist being removed by cleaning. You don't want to have to disassemble the entire exchanger for cleaning after every use!
A good analogy is how recent regulation changes have required elimination of even trace amounts of beryllium from most aluminum castings. To comply with this requirement, aluminum foundries must use equipment that has never previously been used to process any aluminum containing beryllium. They must have documentation to prove this if they deliver castings for certain applications, like products being exported to the EU.
The real question should can this heat exchanger be cleaned and kept hygienic.
The plate and frame heat exchangers used for this service are a special design so that they can be cleaned daily, and not trap traces of contamination.
You need to find a unit that meets A3 or EHEDG standards.
Plymouth Tube
Elastomers and gaskets are a real source of pain in this service.
Plymouth Tube
