Chilled Water Line ( Malleable Iron or Mild Steel )
What's the difference between Malleable Iron Pipe Fittings and Mild Steel Pipe Fittings? Which one is used in Chilled water line? It seems that Malleable Iron is normally threaded but not welded??? Why is it so? Please let me know the answer technically ( eg : Chemical Composition, Ductility )..... What are the advantages of Malleable Iron and Mild Steel overreach other?... Upto what size is malleable Iron Pipe Fittings found?? ( I presume upto 2" )??
RE: Chilled Water Line ( Malleable Iron or Mild Steel )
sandeshrego,
Go to www.google.com and try "malleable iron vs. steel pipe fittings" in search tab.
You will find all information you needed.
Kurt
