Create Point on Curve
I am really stuck at this.
How do I create a point on curve at distance (eg.30mm)
In CATIA V5, its quite easy, select curve, enter the required distance & done.
I am not able to figure out in Nx. (Attached ref. model.)
Sundeep P.
Nx 7.5.0.32
Sundeep P.
Nx 7.5.0.32
RE: Create Point on Curve
if you mean the distance to the beginning of the curve, just create a point, switch the type to "point on curve" and enter the distiance on the location on curve.
Best regards
Carsten
I've tried the said option but in vain.
Sundeep P.
Nx 7.5.0.32
from Menu: Insert - Datum/point - point
Then you have the options from the further post.
Additionally I had to select Offset Option--> Along Curve --> Select the curve--> Enter distance (Arc Length)
Seems i was missing this important step.
Sundeep P.
Nx 7.5.0.32
Tomas
Point with an option of
a. Distance on Curve
or
b. Offset Along Curve
And they are spending lots of resources on changing the interface, ribbon bars,etc..
