Insulation coordination
How to calculate required distance between arcing horn on insulator (Line side to tower side) of 220 KV transmission line for line having altitude of 1500 m to 2000 m above mean sea level.
Does this distance depend on elevation of line ? Does it depend on rated impulse withstand voltage of insulator ?
In India its value is 2130 mm considering normal altitude . Is this value is similar to other country practice ?
Nitin Patel
Nitin Patel
RE: Insulation coordination
_____________________________________
I have been called "A storehouse of worthless information" many times.
We follow Indian code IS-5613 for lines in our country. We are doing lot of works for other countries also where we follow EN , NESC etc. Most of the time client specify required distance. As per my observation it is same as live metal clearance required under no swing position. What distance you provide as per NESC ? As per NESC 1% extra clearance is required above 1000m for every 100m. So for line at 1500m altitude , extra clearance is (1500-1000)/100 * 1 = 5% extra clearance require. Correct me if I am wrong.
