Simple thermal efficiency check
The working fluid of a power plant executes a thermodynamic cycle with thermal efficiency of 40%. The working fluid is heated by the hot gases in a coal-fired furnace, and cooled by water from a river. How much heat transfer from the hot gases occurs, for each joule of heat transfer to the river water?
So, I just used the thermal efficiency equation: n = 1 - Q out / Q in. Plugging in 0.4 for n , and 1 Joule for Q out.
I calculated 0.714 Joules for an answer. Is this correct?
RE: Simple thermal efficiency check
Qin > Qout Unless you are measuring the water at the inlet and outlet?
How and where you measure Qin and Qout would be interesting.
