Carburizing of 8620 Material
I have a question that someone can answer. I have an Engineering Drawing that requires Case Harden to 88.5-91.5 HR15N. It does not say anything
about what the Core Hardness should be. When you Carburize 8620 you could end up with a range of 25 to 45 HRC range in your Core Hardness numbers.
Should the I ask the customer what the Core Hardness should be? Looking for an answer.
RE: Carburizing of 8620 Material
