Hydro-Test for P91 Pipe Spool
I have to Hydrotest a heavy wall (1.38") P91 pipe spool.
I have elliptical heads that are perfect in size for this but they are made from 516-70.
Does anyone see any problem in welding these CS heads to the Grade 91 pipe material. The weld will be PWHT'd and I have checked that the CS material with not exceed 90% yield during the hydrotest. After hydro, the heads will be removed and the weld preps will be machined back on the Gr. 91 pipe.
thanks
thanks
RE: Hydro-Test for P91 Pipe Spool
Thanks Again
