Air-Oil Separation
Air-Oil Separation
I am going to use a vacuum separator to separate air from Dexron III oil at 150F and 5 psia. A vacuum pump on the air outlet will produce the vacuum, and a PD pump on the oil will pump out the oil. We have 60gpm oil and 50scfm air. I have two questions - 1) how much oil vapor will carry over into the air at 5 psia (I don't have a distillation curve), and 2) Do I need a condenser to drop oil vapor out of the vacuum pump discharge (at atmospheric pressure)? I'd appreciate any advice or references. I can provide a P&ID if you want.
RE: Air-Oil Separation
