Can I make this option stick?
See Attachment.
RE: Can I make this option stick?
File -> Utilities -> customer defaults
It is probably under the Gateway tab someplace
Create a new role by RMB in the role palette, then tick the box for Save Dialog Memory (see image).
Anthony Galante
Senior Support Engineer
NX5.0.6, NX6.0.5, NX7.5.5, NX8.0.0 -> NX8.0.3
NX8.5.0 -> NX8.5.3, NX9.0.0 -> NX9.0.2, NX10 Beta
Your suggestions seems like it should work but for whatever reason it did not. Thoughts? Advice?
Trent
Maybe that will help. For me the setting you mentioned is remembered when I restart my session.
Ronald van den Broek
Mechanical Engineer
Cad Environment Coordinator
Wärtsilä, Propulsion Services
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP EliteBook 8570W Intel(R) Core(TM) I7-3740QM CPU @ 2.70GHz, 16Gb Win7 64B
