I need a small ( ~10000BTU) AC unit I can mount on top of locomotive crane for cooling cab.
I was told an RV AC unit would not be able to handle the vibration, any ideas or experence with this?
Thanks.
Thanks.
RE: I need a small ( ~10000BTU) AC unit I can mount on top of locomotive crane for cooling cab.
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
B.E.
You are judged not by what you know, but by what you can do.
There are units made for Light Rail Vehicle Cabs.
Dedicated, purpose built units for such things are expensive.
So often times RV units are used, because they are cheap. With the understanding that it's a throw-away when it fails.
You need to refine your choices.
B.E.
