Revision block notes management
RE: Revision block notes management
NX8, please......
MZ7DYJ
The note lost its associative origin. Drag the note a small distance then move it back or use the edit origin tool to pick a new origin point.
www.nxjournaling.com
It doesn't move anymore.......
MZ7DYJ
I'd like to know if there's a way
to make this note active again......
MZ7DYJ
Edit -> Annotation -> origin, select the note then press OK.
when you do what Cowski said uncheck Associative in the Origin Tool menu box
You can if you want, but there's no need.
Great!
Thank you Cowski and Jerry!
MZ7DYJ
