Why PWHT can be replaced CTOD test
when i read some project structure spec, they require CTOD test for thickness above 60mm but we no need to do that, if you replace PWHT.
pls explain to me understand why PWHT can be replaced CTOD test
RE: Why PWHT can be replaced CTOD test
Why CTOD test can be avoided when we performing PWHT, What is root case.
"If you don't have time to do the job right the first time, when are you going to find time to repair it?"
