Humidity Soaking Test
Good day,
I have environment test running at high temperature & high humidity 65degC/90%RH, apparently the chamber was trip and the test was stop with 3 hours to complete this 24 hours soaking test.
Base on engineering judgement, can the test continue the remaining 3 hours the next day to complete entire test profile? Is there any deviation on the test results collected?
Alvin
Alvin
RE: Humidity Soaking Test
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
Answers to these will help you get an answer to your question.
Whereas, the intention of this test is to expose the corrosion or other cosmetic defects if the product was kept in high temp and humid environment in long period.
Alvin
TTFN
Let me know if this is not a requirement for all humidity soaking test and there is a good reason for continue soaking even there is a interruption during testing. Also for temperature soaking as well.
Cheers
