Ifpexol Methanol Function
Dear All
Can anybody help to solve my problem
Is Methanol can be used as SOLE desiccant agent for dehydration system WITHOUT presence of Glycol (Ex : TEG) OR Methanol is only work as Hydrate Inhibitor to achieve optimum process in dehydration system so we must use Glycol as Primary Desiccant Agent?
Appreciate for your Comment and response
Best Regards
Zachari Alamsyah
Best Regards
Zachari Alamsyah
RE: Ifpexol Methanol Function
MeOH acts as a hydrate/ice inhibitor and the low temperature causes the moisture (and light HC) to condense.
The tric is that you recycle some of the water to "wash" the condensate and thereby avoid excessive MeOH losses with the HC condensate.
Best regards, Morten
http://www.prosernat.com/en/processes/gas-dehydrat...
Zachari Alamsyah
