VBA - Copy Selectionset entities to other layer
I need to create a Visual Basic Routine to copy entities to other layer, using acselectionsetall.
Thank´s
RE: VBA - Copy Selectionset entities to other layer
Just a few questions,
Are you copying any block references and do you want every single entity to "be" on this target layer (including the ones inside the block)?
BU
Many thank's for your fast response
I need to copy everithing on a layer to another layer, using the VBA (selectionset).
At the momment I'm able to work whith selectionsets, but I don't know how to move or copy that information to other new layer (or not new).
I would be very gratfull if you could help me, PPPPlllleeeeaaaasssssseeeeee.
Best regard,
António Miranda
Since you know about selection sets already, this should iterate through all the items in your selection set and reassign their layers. Let me know if this does what you want.
Dim acEnt as AcadObject
If acSelSet.Count = 0 Then 'didn't find any
    Exit Function
Else
    For Each acEnt In acSelSet 'each item in selection set
        acEnt.Layer = yourNewLayer
        acEnt.Update
    Next acEnt
End If
There is a list routine in the AutoCAD express tools that does what you need.
Not 'list'  s be 'lisp' sorry.
