Sliding plates
Sliding plates
Sliding plates
In regard with the subject, Can anyone tell me about the difference between Graphite & Graphite-bronze plates?.,
Also which will sustain at elevated temperatures comparing with PTFE?
Which material has got high load bearing capacity?
RE: Sliding plates
What temperature, exactly, is "elevated", to you?
Mike Halloran
Pembroke Pines, FL, USA
RE: Sliding plates
Hi Mike,
It is said to be +150 deg C.,
RE: Sliding plates
I guess both, for 150ºC are better than PTFE
